How To Fix Vertical Lines On An iPhone Screen After Replacement
  1. How To Fix Vertical Lines On An iPhone Screen After Replacement, Electro-Static Discharge (ESD): step 1, image 1 of 1
    Tool used on this step:
    Anti-Static Mat
    $24.99
    Buy
    • ESD is a common culprit behind display malfunction.
    • Ground yourself and your device to discharge any built up static charge before repairing your phone. The best way to do this is to use an anti-static mat and wear an anti-static wrist strap.
  2. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: step 2, image 1 of 3 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: step 2, image 2 of 3 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: step 2, image 3 of 3
    • Check the display connections on the cables and the logic board. Dirt, dust or debris can cause a faulty connection and should be cleaned with a soft brush and high concentration isopropyl alcohol (at least 90%). Inspect the connectors and clean as necessary.
    • Isopropyl alcohol is a mild skin and eye irritant. Use gloves and eye protection while working with isopropyl alcohol.
  3. How To Fix Vertical Lines On An iPhone Screen After Replacement, Damaged IC Connector: step 3, image 1 of 1
    • The display has an IC that could be damaged. Check particularly on the upper left and right corners. Any signs of damage indicate the part is defective and needs to be replaced with a new one.
Matt Zieminski
38,240 Reputation
13 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 41
Past 7 Days: 320
Past 30 Days: 1,317
All Time: 455,774
