How To Fix Torn Winter Earmuffs
  1. How To Fix Torn Winter Earmuffs, How To Fix Torn Winter Earmuffs: step 1, image 1 of 1
    • Cut approximately 30 cm of thread with scissors.
    • The thread length will vary depending on the size of the area that needs to be sewn.
  2. How To Fix Torn Winter Earmuffs: step 2, image 1 of 1
    • Insert the sewing thread through the eye of the needle.
    • Keep your fingers away from the sharp tip of the needle to avoid injury. If necessary, use a thimble to protect your finger.
    • If you have trouble getting the thread through the eye of the needle, you can lick the tip of the thread. This will tighten the thread fibers and allow easier insertion into the needle.
  3. How To Fix Torn Winter Earmuffs: step 3, image 1 of 1
    • Pull the thread through the eye of the needle until equal amounts of thread are on each side.
    • This is called a double thread, and it makes the thread stronger. It is not required, but it is helpful.
  4. How To Fix Torn Winter Earmuffs: step 4, image 1 of 2 How To Fix Torn Winter Earmuffs: step 4, image 2 of 2
    • Tie a solid knot around the needle to secure the thread, repeating if necessary.
  5. How To Fix Torn Winter Earmuffs: step 5, image 1 of 2 How To Fix Torn Winter Earmuffs: step 5, image 2 of 2
    • Using an invisible seam stitch, sew the earmuff onto the headband.
    • For easier visibility, these images show a thread color that contrasts with the earmuffs. Be sure to choose a thread color that matches with your earmuffs.
  6. How To Fix Torn Winter Earmuffs: step 6, image 1 of 3 How To Fix Torn Winter Earmuffs: step 6, image 2 of 3 How To Fix Torn Winter Earmuffs: step 6, image 3 of 3
    • Pull the thread tight and tie a solid knot to secure it on the earmuff.
  7. How To Fix Torn Winter Earmuffs: step 7, image 1 of 3 How To Fix Torn Winter Earmuffs: step 7, image 2 of 3 How To Fix Torn Winter Earmuffs: step 7, image 3 of 3
    • Near the knot, insert the needle and thread into the earmuffs.
    • Pull the needle and thread out of the earmuffs towards yourself.
  8. How To Fix Torn Winter Earmuffs: step 8, image 1 of 2 How To Fix Torn Winter Earmuffs: step 8, image 2 of 2
    • Trim the excess thread.
  9. How To Fix Torn Winter Earmuffs: step 9, image 1 of 2 How To Fix Torn Winter Earmuffs: step 9, image 2 of 2
    • Locate any additional excess thread.
    • Pull the earmuff fabric gently to tuck the thread inside.
You have now fixed your winter earmuffs. Congratulations!
2 other people completed this guide.
Violet Ichel
187 Reputation
1 Guide authored
UC Davis, Team 3-6, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 3-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G6
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 86
All Time: 349
