How To Fix Overused Screw Holes In Book Shelves
  1. How To Fix Overused Screw Holes In Book Shelves, New screw holes for better support: step 1, image 1 of 3 How To Fix Overused Screw Holes In Book Shelves, New screw holes for better support: step 1, image 2 of 3 How To Fix Overused Screw Holes In Book Shelves, New screw holes for better support: step 1, image 3 of 3
    • If the distance between the screw and the edge is less than 1/8", move to Step 2.
    • If the distance is more than 1/8", take the wider sized screw (min. +1/32") and use the screwdriver to screw the boards back together.
  2. How To Fix Overused Screw Holes In Book Shelves: step 2, image 1 of 1
    • Unscrew your bookshelf and use the two sideboards to proceed.
    • Draw a line along the tablet with a pencil 1/8" below the old screw hole if you are looking at the board horizontally.
    • Make sure the line is parallel to the edge.
  3. How To Fix Overused Screw Holes In Book Shelves: step 3, image 1 of 1
    • Measure the exact distance between the outside edge of the circular saw and its blade.
    • That would be the distance you need between the pencil line and the wooden piece.
  4. How To Fix Overused Screw Holes In Book Shelves: step 4, image 1 of 1
    • Clamp the wooden piece on your sideboard; one clamp for each side.
    • You can use any object which is straight and at least 4 inches longer than the sideboard's width.
  5. How To Fix Overused Screw Holes In Book Shelves: step 5, image 1 of 1
    • Put on your safety glasses.
  6. How To Fix Overused Screw Holes In Book Shelves: step 6, image 1 of 2 How To Fix Overused Screw Holes In Book Shelves: step 6, image 2 of 2
    • Cut along the wooden piece. Gently apply pressure on the corner for a clean straight cut.
  7. How To Fix Overused Screw Holes In Book Shelves: step 7, image 1 of 1
    • Use some sandpaper to clean the edges. Do so by rubbing the rough side of the sandpaper to the freshly cut edge until desired look.
  8. How To Fix Overused Screw Holes In Book Shelves: step 8, image 1 of 1
    • Mark the holes at the exact same place they were before, by placing the piece you just cut next to it or measuring each hole.
    • Drill the holes.
    • Be aware that you will drill through tablet; so put something under it.
  9. How To Fix Overused Screw Holes In Book Shelves: step 9, image 1 of 1
    • Screw the boards together, exactly how they were in the beginning.
    • Your bookshelf should look now the exact same but a little bit shorter.
    • Now you are ready to put back the books into your shelf.
To reassemble your device, follow the instructions that came with the bookshelf, or follow these steps in reverse order.
2 other people completed this guide.
Alexander Eduardo Esser
187 Reputation
1 Guide authored
Cal Poly, Team 15-6, Green Fall 2015 Member of Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 26
All Time: 2,853
