How to disassemble for cleaning
  1. How to disassemble for cleaning, Unscrew the back plate: step 1, image 1 of 3 How to disassemble for cleaning, Unscrew the back plate: step 1, image 2 of 3 How to disassemble for cleaning, Unscrew the back plate: step 1, image 3 of 3
    • Remove 10 screws (8mm) securing the back plate.
    • Remove 4 screws (7mm, ball head) securing the handrest plate.
  2. How to disassemble for cleaning, Remove the handrest plate: step 2, image 1 of 1
    • Lift the handrest plate and pull it free, away from the rest of the unit.
  3. How to disassemble for cleaning, Remove the back plate: step 3, image 1 of 2 How to disassemble for cleaning, Remove the back plate: step 3, image 2 of 2
    • After unscrewing, the back plate is now loose, and can be lifted gently to separate it.
    • Lift up the primary cable to free it from the casing.
  4. How to disassemble for cleaning, Unscrew the membrane layers: step 4, image 1 of 3 How to disassemble for cleaning, Unscrew the membrane layers: step 4, image 2 of 3 How to disassemble for cleaning, Unscrew the membrane layers: step 4, image 3 of 3
    • Remove 9 screws (5mm) that are securing the membrane layers.
    • Remove the plastic holder but retain it in a safe place, as it is used to restrict the data cable from moving freely and will need to be returned.
    • Gently pull the data cable (black/red) to disconnect it.
  5. How to disassemble for cleaning, Lift the membrane layers: step 5, image 1 of 3 How to disassemble for cleaning, Lift the membrane layers: step 5, image 2 of 3 How to disassemble for cleaning, Lift the membrane layers: step 5, image 3 of 3
    • Start to gently remove the membrane cover, peeling off the layers beneath it as well.
    • Caution: take care not to damage the striped grey data cables, which connect all the layers.
  6. How to disassemble for cleaning, Remove the plastic membrane: step 6, image 1 of 1
    • Peel off the plastic membrane.
  7. How to disassemble for cleaning, Separating the front plate: step 7, image 1 of 3 How to disassemble for cleaning, Separating the front plate: step 7, image 2 of 3 How to disassemble for cleaning, Separating the front plate: step 7, image 3 of 3
    • Push with moderate force to separate the keyframe (beige) from the front plate (black).
    • You should apply pressure at each hook (marked in blue).
    • Optional: prior to completing this step, remove all keycaps from the frame (Step 9). This may make it easier for you to apply pressure to the board, with less fear of breakage from undue force.
  8. How to disassemble for cleaning, Separated frame and front plate: step 8, image 1 of 3 How to disassemble for cleaning, Separated frame and front plate: step 8, image 2 of 3 How to disassemble for cleaning, Separated frame and front plate: step 8, image 3 of 3
    • Photos.
  9. How to disassemble for cleaning, Push out the keycaps: step 9, image 1 of 2 How to disassemble for cleaning, Push out the keycaps: step 9, image 2 of 2
    • Push out each keycap using mild pressure from your finger.
    • You should push from the inside (beige frame) to the outside. Do not push the keys the other way around.
    • Optional: Using a blunt tool (like the end of a screwdriver) can help you push out the keycaps quicker than fingers.
    • Tip: Store the keycaps safely in a plastic container, in order of rows. It is very easy to lose keys.
  10. How to disassemble for cleaning, Re-insert keycaps when done: step 10, image 1 of 2 How to disassemble for cleaning, Re-insert keycaps when done: step 10, image 2 of 2
    • To return the keycaps to the frame, push them in using your fingers from the front.
    • Call up your photo of the keyboard layout and review it to ensure you are placing each keycap in the right order and place.
    • You may need to consult a guide on the QWERTY (or other relevant layout) keyboard layout to ensure you are familiar with the correct key order when reassembling the keycaps.
  11. How to disassemble for cleaning, Keycaps with long brace: step 11, image 1 of 1
    • The following keys have a long metal brace to support them. To remove: gently push with great care out of the frame.
    • SHIFT (2 keys)
    • Enter
    • Backspace
    • Keypad Plus (+)
    • Keypad Enter
    • Keypad Zero/Insert (0)
    • Space Bar
  12. How to disassemble for cleaning, Re-insert keycaps with long brace: step 12, image 1 of 2 How to disassemble for cleaning, Re-insert keycaps with long brace: step 12, image 2 of 2
    • Observe the correct alignment for the metal brace. The brace must sit tight in its dedicated, raised rack.
    • Place the keycap over the top of the hole, and push it down gently. Unlike the other normal keycaps, you should feel some resistance when doing so.
    • Now, push the keycap with greater force until a click is heard.
    • Check that the key moves as one, by pressing with your finger on its left and right hand sides to confirm that the key moves effortlessly without obstruction. here is web > keyboardtestt.com
To reassemble, follow the instructions in reverse order.
Test your keyboard after reassembly by re-connecting its USB plug, opening up a word processor and typing content. You can also use http://keyboardtester.com or a similar tool to ensure the keyboard is reporting keystrokes accurately.
3 other people completed this guide.
Sebastian Reategui
371 Reputation
1 Guide authored
5 Guide Comments
help i did this and now my keyboard is not working anymore
Viorel - Reply
Are you sure that both data cables are connected? Do any of the membrane layers look torn or ripped?
Sebastian Reategui -
hey nice to meet you i have that keyboard and is broken , the plastic membrane ho detect the butons is not working because i drop a glass of water on it , so i have a cueston , do you know if i can buy that piece ? is the one whit the form like circuits in the pass 5
thank you very much for reading me
youngmi_k.pop - Reply
Hello, recently the A key of my anansi has become mushy, removing the key cap and comparing the membrane to the key next to it, shows that it broke in a way that it makes the upper part of the membrane go inside the lower, thus giving the key that mushy feeling. Is there any way to fix the plastic membrane from this keyboard? or do i have to buy another keyboard. Thanks
Joaquin Ugarte Torres - Reply
My impression is that you would be looking at buying another keyboard. The components are quite proprietary and that there is unlikely to be a replacement of the whole membrane readily available. I’d do a cursory search on eBay. I can’t see what kind of damage that little area has so couldn’t say if the spot could be repaired alone.
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 106
All Time: 7,355
