How to Wash and Dry a Patagonia Down Jacket
  1. How to Wash and Dry a Patagonia Down Jacket, Prepare your jacket: step 1, image 1 of 3 How to Wash and Dry a Patagonia Down Jacket, Prepare your jacket: step 1, image 2 of 3 How to Wash and Dry a Patagonia Down Jacket, Prepare your jacket: step 1, image 3 of 3
    • Wipe away any dirt and debris.
    • Spot clean stains using dish soap or rubbing alcohol. For detailed guidance, see Spot Cleaning Technical Gear.
    • Zip up the main zipper.
    • Unzip pocket zippers so they get cleaned out in the wash.
    • Don't forget to check the pockets for any treasures or love notes you may have forgotten!
    • Loosen elastic drawcords and fasten hook-and-loop closures in their loosest position.
  2. How to Wash and Dry a Patagonia Down Jacket, Patch any holes: step 2, image 1 of 2 How to Wash and Dry a Patagonia Down Jacket, Patch any holes: step 2, image 2 of 2
    • Carefully examine the jacket for holes or tears and patch them with repair tape.
    • Allow the adhesive on the tape to fully cure or the tape may come off in the wash. This can take up to 24 hours so do this part well in advance!
  3. How to Wash and Dry a Patagonia Down Jacket, Load the washing machine: step 3, image 1 of 3 How to Wash and Dry a Patagonia Down Jacket, Load the washing machine: step 3, image 2 of 3 How to Wash and Dry a Patagonia Down Jacket, Load the washing machine: step 3, image 3 of 3
    • Place the jacket in the washing machine.
    • If you have a Guppyfriend bag or similar microplastics filter bag, use it to reduce microfiber shedding.
    • Add only 1–3 down garments at a time. Technical garments need room to move freely in the wash.
    • Ideally, use a front-loading washer.
    • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scrapes.
    • If all you've got is a top-loader, use a delicates bag or Guppyfriend to protect the jacket.
  4. How to Wash and Dry a Patagonia Down Jacket, Add detergent: step 4, image 1 of 2 How to Wash and Dry a Patagonia Down Jacket, Add detergent: step 4, image 2 of 2
    • Add technical gear soap or gentle biodegradable laundry detergent to the washing machine.
    • Patagonia® recommends Storm Down Wash, which is specially formulated for down-filled items.
    • For standard detergent, choose one that's liquid, biodegradable, and free of dyes. Look for labels like "organic" or "sensitive skin."
    • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
  5. How to Wash and Dry a Patagonia Down Jacket, Set the washing machine: step 5, image 1 of 2 How to Wash and Dry a Patagonia Down Jacket, Set the washing machine: step 5, image 2 of 2
    • Set the load size to small or medium, depending on how many garments you're washing.
    • Set the water temperature to cold or warm.
    • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
    • Set the spin cycle to medium. High spin speeds clump the down and low spin speeds don't remove enough water. Both scenarios increase dry time.
    • Start the washing machine.
  6. How to Wash and Dry a Patagonia Down Jacket, (Optional) Pre-dry: step 6, image 1 of 2 How to Wash and Dry a Patagonia Down Jacket, (Optional) Pre-dry: step 6, image 2 of 2
    • Run a second rinse cycle to ensure all soap is removed. Residue can affect loft and water resistance.
    • Hang dry for a few hours or overnight after the rinse cycle. This will cut the dryer time significantly.
    • Gently separate clumped feather sections by hand.
  7. How to Wash and Dry a Patagonia Down Jacket, Load the dryer: step 7, image 1 of 2 How to Wash and Dry a Patagonia Down Jacket, Load the dryer: step 7, image 2 of 2
    • Tumble drying in a machine is essential. Air drying alone will flatten the down and reduce insulation.
    • Remove the jacket from the washing machine and place it in the dryer.
    • If you used a Guppyfriend or washing bag, take the jacket out before drying.
    • Double-check that any repair tape is still secure.
    • Toss in 2–3 dryer balls, clean tennis balls, or rolled-up socks.
    • These help break up clumps and restore loft by bouncing around during the cycle.
  8. How to Wash and Dry a Patagonia Down Jacket, Tumble dry low: step 9, image 1 of 1
    • Set the dryer to a low heat setting.
    • Tumble dry until the jacket is fully dry and the insulation is lofted. This could take from 30 minutes to over 2 hours depending on the size of the baffles and the thickness of the fabric.
    • The fabric will feel dry to the touch long before the interior feathers are un-clumped and fully dry. You'll know that it's done when it has re-lofted to its original poofy state.
    • Periodically flip the jacket inside out for even drying.
  9. How to Wash and Dry a Patagonia Down Jacket, All done!: step 10, image 1 of 1
    • Your down jacket is clean, fluffed, and ready to keep you warm on your next adventure.
    • Get back out there!
Finish Line
12 other people completed this guide.
Brittany McCrigler
90,451 Reputation
142 Guides authored
3 Guide Comments
The NikWax wash stuff says to use a front loading washer. Is that really necessary? Or are they just messing with me. =)
jotepka - Reply
Front loading washers are gentler on clothes than top loaders so less chance of damaging relatively delicate down jackets.
Pete -
Inexpensive and warm down jackets have long since become part of our wardrobe. And almost every jacket has a warning label prohibiting wash and dry it at home.But enterprising housewives long found a way to wash down jackets at home. It turns out that it is not so difficult if you know some tricks. Here you will find tips how to wash down jacket in the washing machine and by hand https://pinkycloud.com/how-to-wash-a-dow....
It is also very important to know how to store down jackets, it very much depends on how long you will wear it http://triplefatgoose.com/blog/how-to-ta... Here are details and even more
Dana Lawler - Reply
Past 24 Hours: 28
Past 7 Days: 312
Past 30 Days: 1,290
All Time: 162,791
