How to Replace the Net on a Basketball Hoop
  1. How to Replace the Net on a Basketball Hoop, Net: step 1, image 1 of 1
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: step 2, image 1 of 3 How to Replace the Net on a Basketball Hoop: step 2, image 2 of 3 How to Replace the Net on a Basketball Hoop: step 2, image 3 of 3
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: step 3, image 1 of 1
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: step 4, image 1 of 1
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: step 5, image 1 of 1
    • Step down from the ladder and play ball.
Now that you've replaced your net, you're ready play some basketball.
3 other people completed this guide.
Kevin A Walker
164 Reputation
1 Guide authored
Cal Poly, Team 23-3, Green Winter 2015 Member of Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Members
13 Guides authored
3 Guide Comments
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - Reply
i don't have these things were I can like put the net in
leon reichert - Reply
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 242
All Time: 119,853
