How to Replace a Watch Strap
  1. How to Replace a Watch Strap, Watch Strap: step 1, image 1 of 1
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: step 2, image 1 of 2 How to Replace a Watch Strap: step 2, image 2 of 2
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: step 3, image 1 of 2 How to Replace a Watch Strap: step 3, image 2 of 2
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: step 4, image 1 of 2 How to Replace a Watch Strap: step 4, image 2 of 2
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: step 5, image 1 of 3 How to Replace a Watch Strap: step 5, image 2 of 3 How to Replace a Watch Strap: step 5, image 3 of 3
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: step 6, image 1 of 3 How to Replace a Watch Strap: step 6, image 2 of 3 How to Replace a Watch Strap: step 6, image 3 of 3
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: step 7, image 1 of 3 How to Replace a Watch Strap: step 7, image 2 of 3 How to Replace a Watch Strap: step 7, image 3 of 3
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: step 8, image 1 of 3 How to Replace a Watch Strap: step 8, image 2 of 3 How to Replace a Watch Strap: step 8, image 3 of 3
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
You have completed the fix! We hope this guide has helped.
6 other people completed this guide.
domenicruffino
308 Reputation
1 Guide authored
Cal Poly, Team 14-2, Green Fall 2015 Member of Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 66
All Time: 11,757
