How to Fix an Overwound Music Box
  1. How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 1 of 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 2 of 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to unscrew the screws at the base of the music box.
    • Remove the outer casing and isolate the mechanism.
  2. How to Fix an Overwound Music Box: step 2, image 1 of 2 How to Fix an Overwound Music Box: step 2, image 2 of 2
    • Gently wipe the mechanism with a cloth to get rid of any settled dust particles.
    • Make sure you wipe all the open and accessible surfaces of the mechanism.
    • Be extremely careful when cleaning the comb and the drum. The comb is delicate and can break when too much pressure is applied. The threads of the cloth can get stuck in the pins of the drum.
  3. How to Fix an Overwound Music Box: step 3, image 1 of 2 How to Fix an Overwound Music Box: step 3, image 2 of 2
    • Slowly turn the winding key in the opposite direction to release the tension built-up in the spring.
  4. How to Fix an Overwound Music Box: step 4, image 1 of 2 How to Fix an Overwound Music Box: step 4, image 2 of 2
    • Tap the base of the mechanism a few times to release the governor assembly.
  5. How to Fix an Overwound Music Box: step 5, image 1 of 2 How to Fix an Overwound Music Box: step 5, image 2 of 2
    • Gently push the governor fan with your fingertip to assist its spin movement.
  6. How to Fix an Overwound Music Box: step 6, image 1 of 3 How to Fix an Overwound Music Box: step 6, image 2 of 3 How to Fix an Overwound Music Box: step 6, image 3 of 3
    • Use a toothpick to reach the flywheel.
    • Push the toothpick forward to spin the flywheel and assist its rotation.
  7. How to Fix an Overwound Music Box: step 7, image 1 of 2 How to Fix an Overwound Music Box: step 7, image 2 of 2
    • Using a narrow nozzle, spray some WD-40 on the spring housing gear and the governor.
    • The nozzle is pointed at the spring housing gear in the first photo, and in the second photo the nozzle is pointed at the governor.
    • In case you don't have a narrow nozzle, you can add a few drops of WD-40 using any other small quantity dropper.
  8. How to Fix an Overwound Music Box: step 8, image 1 of 1
    • Keep the music box playing for a few minutes after it restarts.
11 other people completed this guide.
Gaurangi Sawant
481 Reputation
1 Guide authored
20 Guide Comments
Very clear instructions. However my music mechanism has glue keeping it firmly to the base of porcelain box. How to release it so I can follow your instructions to repair it. It's a Lenox figurine of baby sitting & spinning on a Christmas gift. White with gold accents
Thank you
Beachbabe - Reply
You should be able to loosen the glue with denatured alcohol, acetone or a heat gun, or a hair dryer if you don't have one. Then gently remove the music box. When your finished you can reglue the music box into the figurine with a household glue like E6000.
Kathy -
Mine is in a stuffed animal and i dont want to have to break the plush to fix it
Idk - Reply
With stuffed animals, use a seam ripper to undo the threads of where the fur is sewn, then sew it back together after the repair
Olivia's Furby Repairs -
I would add that unless it is a swiss mechanism you would be better off replacing. I do not usually restore these plastic ones.
musicboxman63 -
Past 24 Hours: 46
Past 7 Days: 455
Past 30 Days: 2,151
All Time: 84,994
