How to Fix a Squeaky Bed Frame
  1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: step 1, image 1 of 1
    • Remove anything that is on the bed frame.
  2. How to Fix a Squeaky Bed Frame: step 2, image 1 of 1
    • Shake the bed frame to pinpoint the area of noise.
  3. How to Fix a Squeaky Bed Frame: step 3, image 1 of 1
    • Identify which type of screw the bedframe uses in the given area.
    • You will need to make use of the corresponding screwdriver throughout the guide.
    • Typically, the bed frame will use the same type of screws throughout.
  4. How to Fix a Squeaky Bed Frame: step 4, image 1 of 1
    • Ensure the components of the bed frame are aligned.
    • Identify gaps between parts of the frame.
    • Tighten the screws where gaps are present
    • Sometimes mismatched components cause squeakiness.
  5. How to Fix a Squeaky Bed Frame: step 5, image 1 of 1
    • Tighten the screws within the area of noise.
    • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
  6. How to Fix a Squeaky Bed Frame: step 6, image 1 of 1
    • Spray WD-40 into all the contact points of the bed frame.
    • This includes screws and intersections of the frame.
    • Be careful of the spray around children and your eyes.
  7. How to Fix a Squeaky Bed Frame: step 7, image 1 of 1
    • This is an alternative for the previous step.
    • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
Reassemble the bed to your liking.
Jennifer Nguyen
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 94
All Time: 2,876
