How To Fix A Hole In Khaki Pants
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: step 1, image 1 of 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: step 2, image 1 of 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: step 3, image 1 of 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: step 4, image 1 of 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: step 5, image 1 of 2 How To Fix A Hole In Khaki Pants: step 5, image 2 of 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: step 6, image 1 of 2 How To Fix A Hole In Khaki Pants: step 6, image 2 of 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: step 7, image 1 of 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: step 8, image 1 of 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: step 9, image 1 of 1
    • Now put your khaki pants on because they are now wearable again and practically new!
Now your old ripped pants look practically new and you can begin wearing them again.
6 other people completed this guide.
Calvin Roth
291 Reputation
1 Guide authored
Cal Poly, Team 17-1, Green Fall 2015 Member of Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 Members
5 Guides authored
5 Comments
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Reply
and 100% maching
Shafikahmed - Reply
Iam shafik i can't do it's and 100% maching
Shafikahmed - Reply
What about if you’re in school and your pants rip?
EMMA MILLER - Reply
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Reply
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 150
All Time: 51,097
