Hover-1 Titan Bottom Left Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Hover-1 Titan Bottom Left Panel Replacement, Bottom Left Panel: step 1, image 1 of 2 Hover-1 Titan Bottom Left Panel Replacement, Bottom Left Panel: step 1, image 2 of 2
      • Flip the hoverboard so the bottom is facing up.
      • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
      Ask FixBot
    2. Hover-1 Titan Bottom Left Panel Replacement: step 2, image 1 of 2 Hover-1 Titan Bottom Left Panel Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
      • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
      • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
      Ask FixBot
    3. Hover-1 Titan Bottom Left Panel Replacement: step 3, image 1 of 3 Hover-1 Titan Bottom Left Panel Replacement: step 3, image 2 of 3 Hover-1 Titan Bottom Left Panel Replacement: step 3, image 3 of 3
      • Grip the bottom left panel and lift up to remove.
      Ask FixBot
Dana Ebe
241 Reputation
2 Guides authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 245
