Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Prerequisite only! This procedure is part of another guide and is not meant to be used alone.
Use this guide to remove the left half of the housing to open a Wacker M1500-120 REV 100 (2016) Concrete Vibrator for servicing.
Tools
Pull up on the quick-disconnect handle to release the lock on the flex shaft.
Remove the flex shaft.
Use a T20 Torx screwdriver to remove the nineteen screws securing the two halves of the device housing.
Lay the device down onto its right side, screw holes facing up.
Remove the rear dust filter.
