House Door Lock Cylinder Replacement
  1. House Door Lock Cylinder Replacement, Lock Cylinder: step 1, image 1 of 1
    • Push out the retaining pin from the inside and remove the door knob.
    Ask FixBot
  2. House Door Lock Cylinder Replacement: step 2, image 1 of 1
    • Unscrew and remove the decorative cover.
    Ask FixBot
  3. House Door Lock Cylinder Replacement: step 3, image 1 of 1
    • Remove the two mounting screws and pull the lock body out from the outside.
    Ask FixBot
  4. House Door Lock Cylinder Replacement: step 4, image 1 of 1
    • Locate the slot on the lock body that engages with the lock cylinder.
    • Turn the knob to retract the latch bolt and open the door.
    • Note its position for reassembly.
    Ask FixBot
  5. House Door Lock Cylinder Replacement: step 5, image 1 of 1
    • Remove the lock cylinder fixing screw.
    • Keep all removed screws and small parts organized for reassembly.
    Ask FixBot
  6. House Door Lock Cylinder Replacement: step 6, image 1 of 1
    • Take out the lock cylinder.
    Ask FixBot
  7. House Door Lock Cylinder Replacement: step 7, image 1 of 1
    • Compare the replacement lock cylinder with the original.
    • Prepare a replacement lock cylinder of the same size and ensure the correct installation orientation.
    Ask FixBot
  8. House Door Lock Cylinder Replacement: step 8, image 1 of 1
    • Insert the new lock cylinder into the door opening and secure it with the fixing screw.
    Ask FixBot
  9. House Door Lock Cylinder Replacement: step 9, image 1 of 3 House Door Lock Cylinder Replacement: step 9, image 2 of 3 House Door Lock Cylinder Replacement: step 9, image 3 of 3
    • Reinstall the lock body from the outside.
    • Make sure the slot properly engages with the lock cylinder.
    • Then turn the exterior knob and verify that the latch retracts normally.
    Ask FixBot
  10. House Door Lock Cylinder Replacement: step 10, image 1 of 1
    • Tighten the adjustment screws for both the interior and exterior knobs.
    • Tighten the decorative cover of the interior knob.
    Ask FixBot
  11. House Door Lock Cylinder Replacement: step 11, image 1 of 1
    • Push the knob firmly inward until it is fully seated in place.
    Ask FixBot
  12. House Door Lock Cylinder Replacement: step 12, image 1 of 1
    • Turn both the interior and exterior knobs to verify that the latch operates correctly and the door opens normally.
    Ask FixBot
Finish Line
Harry
205 Reputation
1 Guide authored
UC Davis, Team 3-6, Whithaus Spring 2026 Member of UC Davis, Team 3-6, Whithaus Spring 2026
UCD-WHITHAUS-S26S3G6
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 27
All Time: 65
