Hot Tools HPK12 Prerequisite Only
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Hot Tools HPK12 Prerequisite Only, Prerequisite Only: step 1, image 1 of 3 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: step 1, image 2 of 3 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: step 1, image 3 of 3
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      Ask FixBot
    2. Hot Tools HPK12 Prerequisite Only: step 2, image 1 of 1
      • Use the metal spudger to push the center pin through to the other side.
      Ask FixBot
    3. Hot Tools HPK12 Prerequisite Only: step 3, image 1 of 2 Hot Tools HPK12 Prerequisite Only: step 3, image 2 of 2
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      Ask FixBot
    4. Hot Tools HPK12 Prerequisite Only: step 4, image 1 of 1
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      Ask FixBot
    5. Hot Tools HPK12 Prerequisite Only: step 5, image 1 of 3 Hot Tools HPK12 Prerequisite Only: step 5, image 2 of 3 Hot Tools HPK12 Prerequisite Only: step 5, image 3 of 3
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      Ask FixBot
    6. Hot Tools HPK12 Prerequisite Only: step 6, image 1 of 3 Hot Tools HPK12 Prerequisite Only: step 6, image 2 of 3 Hot Tools HPK12 Prerequisite Only: step 6, image 3 of 3
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      Ask FixBot
Aaron Whitlock
249 Reputation
2 Guides authored
IUPUI, Team 3-4, Baechle Fall 2016 Member of IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 326
