Hoover Rogue 970 Wheel Replacement
    1. Hoover Rogue 970 Wheel Replacement, Wall Brush: step 1, image 1 of 3 Hoover Rogue 970 Wheel Replacement, Wall Brush: step 1, image 2 of 3 Hoover Rogue 970 Wheel Replacement, Wall Brush: step 1, image 3 of 3
      • Flip the vacuum over so the wall brushes are facing up.
      Ask FixBot
    2. Hoover Rogue 970 Wheel Replacement: step 2, image 1 of 3 Hoover Rogue 970 Wheel Replacement: step 2, image 2 of 3 Hoover Rogue 970 Wheel Replacement: step 2, image 3 of 3
      • Remove the two 8.2 mm screws using a Phillips #2 screwdriver.
      Ask FixBot
    3. Hoover Rogue 970 Wheel Replacement: step 3, image 1 of 1
      • Gently lift up on the wall brushes to remove them from the vacuum.
      Ask FixBot
    1. Hoover Rogue 970 Wheel Replacement, Base: step 4, image 1 of 3 Hoover Rogue 970 Wheel Replacement, Base: step 4, image 2 of 3 Hoover Rogue 970 Wheel Replacement, Base: step 4, image 3 of 3
      • Press the buttons on the brush roll cover inward.
      • Gently pull the brush roll cover away from the vacuum.
      Ask FixBot
    2. Hoover Rogue 970 Wheel Replacement: step 5, image 1 of 3 Hoover Rogue 970 Wheel Replacement: step 5, image 2 of 3 Hoover Rogue 970 Wheel Replacement: step 5, image 3 of 3
      • Pull the brush roll straight out of the vacuum.
      Ask FixBot
    3. Hoover Rogue 970 Wheel Replacement: step 6, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 6, image 2 of 2
      • Flip the vacuum over so that the underside is facing up.
      • Remove the fifteen 9.3 mm screws from the bottom frame with a Phillips #0 screwdriver.
      • Lift the bottom frame away from the vacuum.
      Ask FixBot
    4. Hoover Rogue 970 Wheel Replacement: step 7, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 7, image 2 of 2
      • Remove the two 11.9 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    5. Hoover Rogue 970 Wheel Replacement: step 8, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 8, image 2 of 2
      • Remove the single 5.9 mm screw using a Phillips #0 screwdriver.
      Ask FixBot
    6. Hoover Rogue 970 Wheel Replacement: step 9, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 9, image 2 of 2
      • Flip the device over so that the top side of the vacuum is facing up.
      • Firmly pull the silver face-plate away from the vacuum.
      Ask FixBot
    7. Hoover Rogue 970 Wheel Replacement: step 10, image 1 of 3 Hoover Rogue 970 Wheel Replacement: step 10, image 2 of 3 Hoover Rogue 970 Wheel Replacement: step 10, image 3 of 3
      • Firmly pull the surrounding black and blue cover away from the vacuum.
      • You may need to clasp the vacuum with both hands on opposite sides of the device. Place both thumbs exerting pressure on the center of the device while firmly wrapping your remaining fingers around the edges of the surrounding cover.
      Ask FixBot
    8. Hoover Rogue 970 Wheel Replacement: step 11, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 11, image 2 of 2
      • Remove four 8.7 mm screws using a Phillips #0 screwdriver.
      • Pull the top cover with the 'Hoover Rogue' markings away from the vacuum.
      Ask FixBot
    9. Hoover Rogue 970 Wheel Replacement: step 12, image 1 of 2 Hoover Rogue 970 Wheel Replacement: step 12, image 2 of 2
      • Remove the eight 15.8 mm screws from the vacuum using a Phillips #0 screwdriver.
      • Gently pry along seam with an iFixit opening tool in order to break the glue seals.
      Ask FixBot
    10. Hoover Rogue 970 Wheel Replacement: step 13, image 1 of 3 Hoover Rogue 970 Wheel Replacement: step 13, image 2 of 3 Hoover Rogue 970 Wheel Replacement: step 13, image 3 of 3
      • Firmly grasp the top and bottom portions of the vacuum with each thumb exerting pressure in opposite directions.
      • The device may be glued together making it difficult to pull the vacuum apart. Use of an opening tool may be appropriate to avoid injury to yourself or the vacuum.
      • Disconnect the motherboard from the base assembly.
      Ask FixBot
    1. Hoover Rogue 970 Wheel Replacement, Wheel: step 14, image 1 of 2 Hoover Rogue 970 Wheel Replacement, Wheel: step 14, image 2 of 2
      • Locate wheel assembly.
      • Remove the five 8.7 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Hoover Rogue 970 Wheel Replacement: step 15, image 1 of 3 Hoover Rogue 970 Wheel Replacement: step 15, image 2 of 3 Hoover Rogue 970 Wheel Replacement: step 15, image 3 of 3
      • Lift the wheel assembly out of the vacuum to access the white bundled cable connector connected to the circuit board.
      • Disconnect the white bundled cable connector that connects the wheel assembly to the circuit board.
      • You may find it helpful to place your other hand's index finger and thumb firmly on the white tab to secure it, avoiding injury or damage to the vacuum.
      • Lift the disconnected wheel assembly away from vacuum.
      Ask FixBot
Malcolm Mcdonald
281 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 56
All Time: 377
