Shop the Holiday Gift Guide
Hoover Rogue 970 Battery Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
28
Past 30 Days:
88
All Time:
832
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
If your Hoover Rogue 970 is failing to charge or turn on, this may be an issue with your battery.
The battery is what holds the charge for your device. If this battery is affected, then there will be issues with your device receiving power that allows it to function.
There are potential hazards when replacing the battery on this device such as the battery being swollen. If the battery is swollen look here for proper removal techniques.
Tools
    1. Hoover Rogue 970 Battery Replacement, Battery: step 1, image 1 of 2 Hoover Rogue 970 Battery Replacement, Battery: step 1, image 2 of 2
      • Flip the vacuum over so that the battery cover is facing up.
      • Locate the battery cover.
      Ask FixBot
    2. Hoover Rogue 970 Battery Replacement: step 2, image 1 of 1
      • Remove the two 14.7 mm screws using a Phillips #0 screwdriver.
      • Lift the battery cover up to remove it from the vacuum.
      Ask FixBot
    3. Hoover Rogue 970 Battery Replacement: step 3, image 1 of 3 Hoover Rogue 970 Battery Replacement: step 3, image 2 of 3 Hoover Rogue 970 Battery Replacement: step 3, image 3 of 3
      • If the battery is swollen look here for safety practices.
      • Lift the battery out of the vacuum to access the connected white tab.
      • Disconnect the JST connector that attaches the battery to the vacuum.
      Ask FixBot
Author
with
Chris Kelemen
603 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 88
All Time: 832
