Hoover Presto 2-in-1 Cordless Stick Charger Replacement
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: step 1, image 1 of 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: step 1, image 2 of 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: step 1, image 3 of 3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 2, image 1 of 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 2, image 2 of 2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 3, image 1 of 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 3, image 2 of 2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 4, image 1 of 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 4, image 2 of 2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 5, image 1 of 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 5, image 2 of 2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 6, image 1 of 1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 7, image 1 of 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: step 7, image 2 of 2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
katia zubieta
437 Reputation
4 Guides authored
4 Comments
La pila dónde la puedo encontrar
alejandro rodriguez - Reply
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Reply
Where does one buy the replacement battery?
mytikikitty - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 6,079
