You're viewing a previously published version of this guide. View latest version
This guide will show you how to replace the motor that turns the brush roller in the nozzle. You might need to do this if the brush roll is no longer spinning. Make sure that the device is turned off and the battery removed from it.
Detach the rolling assembly from the body by pushing the button found at the base.
Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
Remove the brush and retainer from the rolling assembly.
The brush will need to be disconnected from the belt.
Remove the eight 4mm Phillips #1 screws from the bottom panel.
Remove the bottom panel.
Remove the motor.
with 3 other contributors
541 Reputation
4 Guides authored
Badges: 7
+4 more badges
USFT-PASSMORE-S18S7G4
4 Members
12 Guides authored
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 75
All Time: 3,522
