Introduction
This guide will walk you through the steps to remove your rotation motor. Though disassembly is simple, it is a difficult process to put back together because you have to solder wires or use a wire connector to reattach a new rotation motor.
Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
Move the rotation motor left and right to reveal the screw connecting it to the fan.
Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
