Introduction
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
Once the screws are removed, lift the motor off its base.
2 other people completed this guide.
2 Comments
Do you know where I can find the fan motor replacement?
