Honeytone N-10 Mini Amp Speaker Replacement
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: step 1, image 1 of 2 Honeytone N-10 Mini Amp Speaker Replacement, Speaker: step 1, image 2 of 2
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: step 2, image 1 of 2 Honeytone N-10 Mini Amp Speaker Replacement: step 2, image 2 of 2
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: step 3, image 1 of 2 Honeytone N-10 Mini Amp Speaker Replacement: step 3, image 2 of 2
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: step 4, image 1 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 4, image 2 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 4, image 3 of 3
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: step 5, image 1 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 5, image 2 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 5, image 3 of 3
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: step 6, image 1 of 2 Honeytone N-10 Mini Amp Speaker Replacement: step 6, image 2 of 2
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: step 7, image 1 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 7, image 2 of 3 Honeytone N-10 Mini Amp Speaker Replacement: step 7, image 3 of 3
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: step 8, image 1 of 1
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: step 9, image 1 of 1
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
Corey Brown
8,688 Reputation
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 23
All Time: 3,502
