Introduction
This guide demonstrates how to remove or replace the main circuit breaker in your Honda EB3000CK2A 3000 Watt Generator.
Use a Phillips #2 screwdriver to remove the five 15 mm screws securing the control box cover.
Use a Phillips #2 screwdriver to remove the four 5 mm screws securing the circuit breaker to the control box panel.
Disconnect the large white connector from the circuit breaker.
One Comment
I have a Honda gen. EM500SK. It has two double outlet GFCI (total 4 110v plugs). These are sensitive to current/voltage fluctuations and in my case I need at least one of these to be a standard no GFIC which is more reliable than the current outlets. Any idea if I can purchase non GFIC outlets from an earlier model of generator and fit them to my current generator?
