Shop the Holiday Gift Guide
Holystone HS 440 Arm Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
69
All Time:
768
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the arm of the drone is having trouble opening or is broken, you will need to replace the arm. The arm of the drone holds the propeller blades and allows the propeller to spin, without the arm the drone is inoperable.
The only tool needed to replace the arm is a Phillips #0 screwdriver. This replacement is simple and prompt, these are the steps to accomplish this task.
Tools
    1. Holystone HS 440 Arm Replacement, Arm: step 1, image 1 of 3 Holystone HS 440 Arm Replacement, Arm: step 1, image 2 of 3 Holystone HS 440 Arm Replacement, Arm: step 1, image 3 of 3
      • Start by removing the 2 mm Phillips #0 screw, located right under the base of the arm.
      • After removing the screw, dispose of the old arm.
      Ask FixBot
    2. Holystone HS 440 Arm Replacement: step 2, image 1 of 2 Holystone HS 440 Arm Replacement: step 2, image 2 of 2
      Ask FixBot
Author
with
Sokudam
392 Reputation
3 Guides authored
1 Guide Comment
مرحبا اريد دراع درون هولي ستون hs440 كم سعرها
Zirar Soufiane - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 69
All Time: 768
