Holy Stone HS720E Propeller Replacement
    1. Holy Stone HS720E Propeller Replacement, Propeller: step 1, image 1 of 2 Holy Stone HS720E Propeller Replacement, Propeller: step 1, image 2 of 2
      • Lay out the drone so that its arms are out and oriented upwards.
      • This will allow to access all the propellers.
      Ask FixBot
    2. Holy Stone HS720E Propeller Replacement: step 2, image 1 of 3 Holy Stone HS720E Propeller Replacement: step 2, image 2 of 3 Holy Stone HS720E Propeller Replacement: step 2, image 3 of 3
      • Remove the two 1 mm screws securing the propeller using a Phillips #00 screwdriver.
      • Some pressure will be needed when unscrewing or it won't be easy due to the swivel mount.
      • Remove the damaged/malfunctioning propeller.
      Ask FixBot
    3. Holy Stone HS720E Propeller Replacement: step 3, image 1 of 1
      • While the swivel mount is exposed, remove any debris found. Removing the debris will improve the drone's performance.
      • When fastening the replacement propeller, be sure that the screws are inserted into the two holes on the swivel mount.
      Ask FixBot
Daniel Martins
215 Reputation
1 Guide authored
UMass Dartmouth, Team 2-3, Konn Fall 2024 Member of UMass Dartmouth, Team 2-3, Konn Fall 2024
UMASSD-KONN-F24S2G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 61
All Time: 490
