Holy Stone HS720E Camera Replacement
    1. Holy Stone HS720E Camera Replacement, Battery: step 1, image 1 of 2 Holy Stone HS720E Camera Replacement, Battery: step 1, image 2 of 2
      • Flip the drone upside down.
      Ask FixBot
    2. Holy Stone HS720E Camera Replacement: step 2, image 1 of 2 Holy Stone HS720E Camera Replacement: step 2, image 2 of 2
      • Press and hold the button on top of the battery.
      Ask FixBot
    3. Holy Stone HS720E Camera Replacement: step 3, image 1 of 2 Holy Stone HS720E Camera Replacement: step 3, image 2 of 2
      • While still holding the button down, slide the battery out towards yourself.
      Ask FixBot
    1. Holy Stone HS720E Camera Replacement, Camera: step 4, image 1 of 2 Holy Stone HS720E Camera Replacement, Camera: step 4, image 2 of 2
      • Remove the screws from both the left and right side of the drone using a Phillips #1 screwdriver.
      Ask FixBot
    2. Holy Stone HS720E Camera Replacement: step 5, image 1 of 1
      • Remove the two screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. Holy Stone HS720E Camera Replacement: step 6, image 1 of 1
      • Using your hand, gently remove the top of the drone.
      Ask FixBot
    4. Holy Stone HS720E Camera Replacement: step 7, image 1 of 2 Holy Stone HS720E Camera Replacement: step 7, image 2 of 2
      • Remove the screws from the lower body of the drone using a Phillips #1 screwdriver.
      Ask FixBot
    5. Holy Stone HS720E Camera Replacement: step 8, image 1 of 2 Holy Stone HS720E Camera Replacement: step 8, image 2 of 2
      • Unplug the wire connected to the motherboard and remove the camera.
      Ask FixBot
James Ducie
142 Reputation
1 Guide authored
UMass Dartmouth, Team 2-3, Konn Fall 2024 Member of UMass Dartmouth, Team 2-3, Konn Fall 2024
UMASSD-KONN-F24S2G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 66
All Time: 637
