Introduction
If you are having trouble trying to figure out how to replace a fan blade? Then coming to the right person to help if the only good way to go. With this guide, I will go through step by step instructions on how to replace the blade in various easy steps.
In the marker, we have the screw that connects the fan to the box. Now using your tool, remove six 2mm Phillips #2 screws.
One Comment
Wow, the step with removing the motor from it’s mount of the 4 screws is totally unnecessary! You obviously have not done these too often — all you have to do is to remove the FRONT fan shroud, and then pull the fan blade (or what’s left of it if replacing) from the front of the motor! WAY too much work with how you explained it here!
