Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement
  1. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement, Bass Valve Pad: step 1, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement, Bass Valve Pad: step 1, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement, Bass Valve Pad: step 1, image 3 of 3
    • Remove the foot screws by hand.
  2. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 2, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 2, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 2, image 3 of 3
    • Remove the bass plate by first lifting the portion of it farthest from the bass buttons and then rotating that part of the plate towards you.
  3. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 3, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 3, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 3, image 3 of 3
    • Remove the arm pins (one on each side) by first rotating them clockwise out from underneath the black metal clip and then sliding them out.
  4. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 4, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 4, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 4, image 3 of 3
    • Raise the black, metal arms. For one of them, you will need to ensure that the air button fits through the metal hole which is attached to the arm.
  5. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 5, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 5, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 5, image 3 of 3
    • Remove the bass machine. Be careful not to snag the ends of the bass buttons.
  6. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 6, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 6, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 6, image 3 of 3
    • Remove the valve cover by first lifting the valve cover arm and then sliding the valve cover off the arm.
  7. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 7, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 7, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 7, image 3 of 3
    • Use the box-cutter to scrape off the remains of the deteriorated valve pad, careful to keep your fingers out of the path of the blade.
  8. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 8, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 8, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 8, image 3 of 3
    • Size and cut your replacement pad by placing the valve cover down on the foam sheet and using the box-cutter to cut as closely to the valve cover as possible.
  9. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 9, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 9, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 9, image 3 of 3
    • Use superglue to glue on the replacement pad, press down firmly on the pad, and then allow the glue to dry for a minute or two.
  10. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 10, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 10, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 10, image 3 of 3
    • Reattach the valve cover by sliding it onto the valve cover arm. Move the bellows to ensure that the air leak has been fixed.
  11. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 11, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 11, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 11, image 3 of 3
    • Re-attach the bass machine.
  12. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 12, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 12, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 12, image 3 of 3
    • Lower the arms and fit the vent button through its slot.
  13. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 13, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 13, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 13, image 3 of 3
    • Re-attach the arm pins and secure them behind the black, metal clip.
  14. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 14, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 14, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 14, image 3 of 3
    • Re-attach the bass plate and use the box-cutter or another tool to fit the air button through its slot in the bass plate.
  15. Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 15, image 1 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 15, image 2 of 3 Hohner Pirola IIIP Accordion: Bass Valve Pad Replacement: step 15, image 3 of 3
    • Screw in the foot screws by hand.
Finish Line
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 1,065
