Introduction
If your humidifier seems to not be turning on, follow this guide to access the power supply board. This guide is an easy-to-follow process of how to remove your power supply board for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace your power supply board.
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Almost done!
