Hitachi HB-B102 Automatic Home Bakery II Belt Replacement
  1. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement, Outer Casing: step 1, image 1 of 2 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement, Outer Casing: step 1, image 2 of 2
    • Make sure to unplug the device before starting.
    • Remove the lid by opening it to a 45 degree angle and pulling out.
  2. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 2, image 1 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 2, image 2 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 2, image 3 of 3
    • Next, remove the two 1.3cm screws that hold on the control panel with a #2 Phillips head screwdriver. These screws, and the rest of the screws in this guide can all be removed using a #2 Phillips head screwdriver.
    • Then pull the control panel out of the device by using a metal spudger to pry it up. Flip it over and look at the back of the motherboard.
  3. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 3, image 1 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 3, image 2 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 3, image 3 of 3
    • You will then have to disconnect the six wires that connect the motherboard to the device. This can be done by firmly grasping a connector and pulling straight out from the unit. Once all of the wires have been disconnected, set aside the control unit.
  4. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 4, image 1 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 4, image 2 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 4, image 3 of 3
    • Remove the five 1cm screws that hold the the casing together. There will be two on each side, and one on the back.
  5. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 5, image 1 of 1
    • Unscrew the four 1.4 cm screws surrounding the slot for the bread pan.
  6. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 6, image 1 of 2 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 6, image 2 of 2
    • Now you can remove the top part of the assembly off by pulling straight up. Don't forget to gently pull your wires through.
  7. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 7, image 1 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 7, image 2 of 3 Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 7, image 3 of 3
    • Flip the machine over so that the bottom is facing straight up. Then unscrew the four feet on the device with a #2 Phillips head screwdriver. The screws will stay in the rubber feet.
    • Next, remove the four 8mm screws on the four sides of the machine. You do not need to unscrew the screws on the front end corners.
    • Once the feet and screws are undone gently pull the metal plate off.
  8. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 8, image 1 of 1
    • Now that the bottom plate and top housing are off, you can gently pull the inner components out of the outer metal housing . This can be done by grabbing hold of the bread pan casing and slowly lifting the entire inner assembly straight up.
    • You now have access to the belt and motor.
  9. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement, Mixing Paddle Drive Belt: step 9, image 1 of 1
    • The Belt assembly can be found on the bottom of the bread maker.
  10. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 10, image 1 of 1
    • Begin by pulling the belt off of the large wheel just slightly at the bottom.
  11. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 11, image 1 of 1
    • Then rotate the large wheel upwards until the belt becomes lose in your hands.
  12. Hitachi HB-B102 Automatic Home Bakery  II Belt Replacement: step 12, image 1 of 1
    • Now that the belt is free you can discard a loose or damaged belt and replace it with a new one.
Mike
397 Reputation
3 Guides authored
Cal Poly, Team 9-2, Banghart Winter 2017 Member of Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Members
7 Guides authored
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 65
All Time: 3,061
