Hitachi CP-X2010N Top Panel Replacement
  1. Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 3 of 3
    • Flip the projector upside down to expose the screws on the underside.
  2. Hitachi CP-X2010N Top Panel Replacement: step 2, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 2, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
  3. Hitachi CP-X2010N Top Panel Replacement: step 3, image 1 of 1
    • Flip projector right side up and orient it so you are facing the rear panel.
  4. Hitachi CP-X2010N Top Panel Replacement: step 4, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 4, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 4, image 3 of 3
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
  5. Hitachi CP-X2010N Top Panel Replacement: step 5, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 5, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 5, image 3 of 3
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
3 other people completed this guide.
Chance Kidd
1,184 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 185
