Up to 20% off select tools
Hinges Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
17
All Time:
135
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Hinges Removal
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the hinges in your Nintendo Game Boy Advance SP.
    1. Hinges Removal, Prepare your Game Boy for disassembly: step 1, image 1 of 3 Hinges Removal, Prepare your Game Boy for disassembly: step 1, image 2 of 3 Hinges Removal, Prepare your Game Boy for disassembly: step 1, image 3 of 3
      • Slide the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge in, remove it.
      Ask FixBot
    2. Hinges Removal, Remove the battery cover: step 2, image 1 of 2 Hinges Removal, Remove the battery cover: step 2, image 2 of 2
      • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Hinges Removal: step 3, image 1 of 3 Hinges Removal: step 3, image 2 of 3 Hinges Removal: step 3, image 3 of 3
      • Lift the edge of the cover near the screw and remove the cover.
      • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
      Ask FixBot
    4. Hinges Removal, Remove the battery: step 4, image 1 of 3 Hinges Removal, Remove the battery: step 4, image 2 of 3 Hinges Removal, Remove the battery: step 4, image 3 of 3
      • Use your finger to lift the battery by the tab on its left edge, then remove it.
      • During reassembly:
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      • Your replacement battery may come with a plastic enclosure that slides over the battery.
      • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
      Ask FixBot
    1. Hinges Removal, Remove the bottom shell: step 5, image 1 of 2 Hinges Removal, Remove the bottom shell: step 5, image 2 of 2
      • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
      • Four 6.3 mm‑long recessed screws
      • Two 4.6 mm‑long screws
      Ask FixBot
    2. Hinges Removal: step 6, image 1 of 2 Hinges Removal: step 6, image 2 of 2
      • Lift the bottom shell straight up and remove it.
      Ask FixBot
    1. Hinges Removal, Remove the power switch cover: step 7, image 1 of 2 Hinges Removal, Remove the power switch cover: step 7, image 2 of 2
      • Use your fingers to lift and remove the power switch cover.
      • Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
      • Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
      • If the switch isn't properly in its cutout, you won't be able to power on your Game Boy.
      Ask FixBot
    2. Hinges Removal, Remove the motherboard screws: step 8, image 1 of 2 Hinges Removal, Remove the motherboard screws: step 8, image 2 of 2
      • Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
      Ask FixBot
    3. Hinges Removal, Prop up the motherboard: step 9, image 1 of 3 Hinges Removal, Prop up the motherboard: step 9, image 2 of 3 Hinges Removal, Prop up the motherboard: step 9, image 3 of 3
      • Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
      • Use your fingers to gently flip the motherboard over the hinges and prop it up.
      Ask FixBot
    1. Hinges Removal, Remove the silicone pads: step 10, image 1 of 3 Hinges Removal, Remove the silicone pads: step 10, image 2 of 3 Hinges Removal, Remove the silicone pads: step 10, image 3 of 3
      • Use tweezers or your fingers to remove the four silicone pads covering the buttons (A and B, D‑pad, brightness, and Start/Select).
      • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
      Ask FixBot
    2. Hinges Removal, Remove the buttons: step 11, image 1 of 3 Hinges Removal, Remove the buttons: step 11, image 2 of 3 Hinges Removal, Remove the buttons: step 11, image 3 of 3
      • Use tweezers or your fingers to remove the buttons (A and B, D‑pad, brightness, and Start/Select).
      • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
      Ask FixBot
    1. Hinges Removal, Open your Game Boy: step 12, image 1 of 1
      • Open your Game Boy to a 90‑degree angle and set it down so the screen is facing up.
      Ask FixBot
    2. Hinges Removal, Remove the rubber screw covers: step 13, image 1 of 3 Hinges Removal, Remove the rubber screw covers: step 13, image 2 of 3 Hinges Removal, Remove the rubber screw covers: step 13, image 3 of 3
      • Use a pair of angled tweezers to pry up and remove all five rubber screw covers.
      • Removing old, brittle covers without damaging them can be tricky. Make sure to pry gently between the cover’s edge and the frame—don’t dig into the cover itself.
      Ask FixBot
    3. Hinges Removal, Remove the screen screws: step 14, image 1 of 2 Hinges Removal, Remove the screen screws: step 14, image 2 of 2
      • Use a tri‑point Y0 screwdriver to remove the five 4.7 mm‑long screws securing screen shells together.
      Ask FixBot
    4. Hinges Removal, Close the main body: step 15, image 1 of 2 Hinges Removal, Close the main body: step 15, image 2 of 2
      • Fully close your Game Boy (the button cutouts should be on top).
      Ask FixBot
    5. Hinges Removal, Remove the hinge cover screw: step 16, image 1 of 3 Hinges Removal, Remove the hinge cover screw: step 16, image 2 of 3 Hinges Removal, Remove the hinge cover screw: step 16, image 3 of 3
      • Use a JIS 00 screwdriver to remove the 6.3 mm‑long screw securing the hinge cover.
      • You may need to use your free hand to hold the screen cable out of the way.
      Ask FixBot
    6. Hinges Removal, Flip your Game Boy over: step 17, image 1 of 2 Hinges Removal, Flip your Game Boy over: step 17, image 2 of 2
      • Flip your Game Boy over.
      Ask FixBot
    7. Hinges Removal, Remove the hinge cover: step 18, image 1 of 2 Hinges Removal, Remove the hinge cover: step 18, image 2 of 2
      • Use your fingers to lift and remove the hinge cover.
      Ask FixBot
    8. Hinges Removal, Remove the top shell: step 19, image 1 of 3 Hinges Removal, Remove the top shell: step 19, image 2 of 3 Hinges Removal, Remove the top shell: step 19, image 3 of 3
      • Depending on the age of your device, the screen may stay attached to its outer shell. If it does, make sure to thread the cable through its cutout while removing the shell.
      • Use your fingers to lift and remove the outer screen shell.
      Ask FixBot
    9. Hinges Removal, Remove the screen: step 20, image 1 of 3 Hinges Removal, Remove the screen: step 20, image 2 of 3 Hinges Removal, Remove the screen: step 20, image 3 of 3
      • Use your fingers to lift and remove the screen, threading the cable through its cutout.
      • If your screen stayed attached to the shell, you may need to gently pry it up with a spudger before removing it.
      • Place the screen foam-side up into its recess, so the cable is near the hinges.
      • Make one loop in the screen cable and then slide it through the cutout.
      Ask FixBot
    1. Hinges Removal, Partially separate the hinges: step 21, image 1 of 3 Hinges Removal, Partially separate the hinges: step 21, image 2 of 3 Hinges Removal, Partially separate the hinges: step 21, image 3 of 3
      • Don't try to force the hinges out of their sockets—you may damage the hinges, crack the shell, or injure yourself.
      • Use the flat end of a spudger to push both hinges partially out of their sockets.
      • You only need to push the hinges out until you feel them click into place.
      Ask FixBot
    2. Hinges Removal, Open the shell: step 22, image 1 of 2 Hinges Removal, Open the shell: step 22, image 2 of 2
      • Full open the shell of your Game Boy.
      Ask FixBot
    3. Hinges Removal, Remove the right hinge: step 23, image 1 of 2 Hinges Removal, Remove the right hinge: step 23, image 2 of 2
      • Use the point of a spudger to push the right hinge fully out of its socket and remove it.
      Ask FixBot
    4. Hinges Removal, Remove the screen bezel: step 24, image 1 of 3 Hinges Removal, Remove the screen bezel: step 24, image 2 of 3 Hinges Removal, Remove the screen bezel: step 24, image 3 of 3
      • Use your fingers to gently lift the right side of the screen bezel.
      • Pull the screen bezel to the right—so it slides out of the left hinge—and remove it.
      Ask FixBot
    5. Hinges Removal, Remove the left hinge: step 25, image 1 of 3 Hinges Removal, Remove the left hinge: step 25, image 2 of 3 Hinges Removal, Remove the left hinge: step 25, image 3 of 3
      • Use your finger to push the left hinge out of its socket and remove it.
      Ask FixBot
Finish Line
Spencer Day
210,586 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 135
