Shop the Holiday Gift Guide
HP EliteBook 1040 G4 Motherboard Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
96
All Time:
2,665
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the Motherboard on the HP Elitebook 1040 G4. The Motherboard is the backbone that ties all components of the computer together. It moves power throughout the device and provides a central place for communication. If you are noticing problems with your computers speed, graphics, or hardware, you may need to replace your motherboard.
To complete this guide, you will need a #T5 Torx head screwdriver and a Phillips #0 and #00 screwdriver.
Before beginning, be sure to completely power off your computer.
Parts
Tools
    1. HP EliteBook 1040 G4 Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
      Ask FixBot
    2. HP EliteBook 1040 G4 Motherboard Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 2, image 2 of 2
      • Lift the back cover up and off the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Motherboard Replacement, Battery: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
      Ask FixBot
    2. HP EliteBook 1040 G4 Motherboard Replacement: step 4, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 4, image 2 of 2
      • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
      Ask FixBot
    3. HP EliteBook 1040 G4 Motherboard Replacement: step 5, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Motherboard Replacement, SSD: step 6, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the single 5 mm screw securing the SSD to the motherboard.
      Ask FixBot
    2. HP EliteBook 1040 G4 Motherboard Replacement: step 7, image 1 of 1
      • Lift the SSD up and out of the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Motherboard Replacement, Fan: step 8, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement, Fan: step 8, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
      • The top left screw may be hidden under shielding tape.
      Ask FixBot
    2. HP EliteBook 1040 G4 Motherboard Replacement: step 9, image 1 of 3 HP EliteBook 1040 G4 Motherboard Replacement: step 9, image 2 of 3 HP EliteBook 1040 G4 Motherboard Replacement: step 9, image 3 of 3
      • Remove the electrical tape to expose the heat sink screws.
      • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
      • Carefully disconnect the pin connector by pulling it from its slot.
      Ask FixBot
    3. HP EliteBook 1040 G4 Motherboard Replacement: step 10, image 1 of 1
      • Carefully remove the wires from the clip to the left of the fan.
      Ask FixBot
    4. HP EliteBook 1040 G4 Motherboard Replacement: step 11, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 11, image 2 of 2
      • Lift and remove the fan and heatsink assembly from the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Motherboard Replacement, Motherboard: step 12, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the five black 4 mm screws securing the motherboard to the device.
      Ask FixBot
    2. HP EliteBook 1040 G4 Motherboard Replacement: step 13, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 13, image 2 of 2
      • Using the same Phillips #0 screwdriver, remove the two silver 6.5 mm screws from the secondary fan placeholder.
      • Remove the fan placeholder from the device.
      Ask FixBot
    3. HP EliteBook 1040 G4 Motherboard Replacement: step 14, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 14, image 2 of 2
      • Carefully disonnect the "Main" and "Aux" cables from the dual band wireless driver.
      Ask FixBot
    4. HP EliteBook 1040 G4 Motherboard Replacement: step 15, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 15, image 2 of 2
      • Remove the ZIF connector from the bottom left of the motherboard by lifting the small grey tab, then pulling the connector out of the slot.
      • For more information on properly disconnecting and removing Zero Insertion Force (ZIF) connectors, please visit this guide.
      Ask FixBot
    5. HP EliteBook 1040 G4 Motherboard Replacement: step 16, image 1 of 1
      • Disconnect and remove the four ZIF connectors from the bottom middle of the motherboard by lifting the small locking tabs, then pulling the connectors out of their slots.
      Ask FixBot
    6. HP EliteBook 1040 G4 Motherboard Replacement: step 17, image 1 of 1
      • Remove the pin connector from the top right corner of the motherboard.
      Ask FixBot
    7. HP EliteBook 1040 G4 Motherboard Replacement: step 18, image 1 of 1
      • Remove the ZIF connector from the top right corner of the motherboard by lifting the locking tab, then pulling the connector out of the slot.
      Ask FixBot
    8. HP EliteBook 1040 G4 Motherboard Replacement: step 19, image 1 of 2 HP EliteBook 1040 G4 Motherboard Replacement: step 19, image 2 of 2
      • Remove the pin connectors in the top right corner of the motherboard by lifting them straight up. The longer, top, connector has a pull tab connected to it to assist in pulling it out.
      Ask FixBot
    9. HP EliteBook 1040 G4 Motherboard Replacement: step 20, image 1 of 3 HP EliteBook 1040 G4 Motherboard Replacement: step 20, image 2 of 3 HP EliteBook 1040 G4 Motherboard Replacement: step 20, image 3 of 3
      • Remove the RTC battery pin connector from the underside of the motheroard.
      Ask FixBot
    10. HP EliteBook 1040 G4 Motherboard Replacement: step 21, image 1 of 1
      • Carefully lift and remove the motherboard.
      Ask FixBot
Author
with
Ryan Cameron
181 Reputation
1 Guide authored
Clemson, Team 4-1, Hunter Fall 2021 Member of Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 96
All Time: 2,665
