Introduction
Does your Heyday Wireless Speaker 8125 refuse to start up? It might be time to replace the battery. Following the steps in this guide will help you replace the battery on your Heyday Wireless Speaker 8125 (model number BTSP47).
Before following this guide, please refer to this device's troubleshooting page where battery related symptoms are present. The Heyday Wireless Speaker 8125 is fitted with a Non-Universal Lithium Ion Battery.
Prior to starting this repair, be sure to power off the device and disconnect from the charger.
Orient the speaker so that it is sitting upright.
Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
Gently remove it from the top of the device.
Use tweezers to remove the four black rubber screw covers.
Use a Phillips screwdriver to remove four 8.9 mm screws underneath the screw covers.
Once all four screws are out, gently pull the black cover out using your hands or use a spudger to pry it out.
Use a Phillips screwdriver to remove four 6.6 mm screws from the motherboard.
Lift the motherboard out of the speaker gently.
Use a Phillips screwdriver to remove three 6.6 mm screws from the triangular plastic support.
Lift the plastic support to reveal the battery underneath.
