Heating Element Contacts
  1. Heating Element Contacts, Heating Element Contacts: step 1, image 1 of 3 Heating Element Contacts, Heating Element Contacts: step 1, image 2 of 3 Heating Element Contacts, Heating Element Contacts: step 1, image 3 of 3
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Heating Element Contacts: step 2, image 1 of 2 Heating Element Contacts: step 2, image 2 of 2
    • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
    • Solder iron can cause burns if used improperly
Austin Wheaton
861 Reputation
4 Guides authored
UW Stout, Team S8-G1, Ogden Spring 2018 Member of UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,964
