Introduction
Is your Cuisinart coffee maker producing cold coffee because the heating element contacts are disconnected? If so, this guide will provide instructions on how to reconnect contacts to the heating element. To complete this task you will need a soldering iron, soldering wire and a T10 driver bit.
Flip the coffee maker over so the bottom is facing upwards.
Use the screwdriver with size 4 extension with the T10 Torxs bit to remove all four 17 mm screws.
Lift the bottom cover off the bottom of the coffee maker.
If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
