Epson Stylus Photo 820 Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
38
All Time:
1,595
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
This guide will show you how to replace the plastic buttons on the Epson Stylus Photo 820 printer, a common fix for when button presses fail to trigger the printer's actions. This problem can be due to worn-out buttons, dirt accumulation, or internal damage. While this repair often resolves non-responsive button issues, it's important to note that other factors, such as electrical faults or software glitches, could also be at play.
Before you begin, ensure you have a small screwdriver handy to remove the printer’s top cover. This involves accessing internal components, so extra care is needed to avoid damaging delicate parts. Additionally, remember to work in a well-lit area to clearly see the small components.
Hazards to be aware of include potential static discharge and the risk of damaging the printer’s internal electronics. Always take precautions, such as grounding yourself, before handling internal components.
IMPORTANT: Before starting, unplug the printer's power cord from the wall to avoid electric shock or damage to the printer.
Tools
    1. Epson Stylus Photo 820 Buttons Replacement, Top Cover: step 1, image 1 of 2 Epson Stylus Photo 820 Buttons Replacement, Top Cover: step 1, image 2 of 2
      • To remove the top cover of the printer, you have to first release it from several tabs.
      • This may take more than one person to complete.
      • These three are the easiest tabs to remove. They are located on the back side of the printer.
      Ask FixBot
    2. Epson Stylus Photo 820 Buttons Replacement: step 2, image 1 of 2 Epson Stylus Photo 820 Buttons Replacement: step 2, image 2 of 2
      • Push the tab in with one of the plastic opening tools.
      • Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
      • Repeat this process with the furthermost right tab, then proceed with the middle tab.
      Ask FixBot
    3. Epson Stylus Photo 820 Buttons Replacement: step 3, image 1 of 3 Epson Stylus Photo 820 Buttons Replacement: step 3, image 2 of 3 Epson Stylus Photo 820 Buttons Replacement: step 3, image 3 of 3
      • It is recommended that Steps 3 and 4 be completed simultaneously. The tabs are identical, just on opposite sides.
      • Insert the pointed end of a spudger into the hole on the bottom left corner of the printer and pry out the tab.
      • This tab is the easiest to break, so be very careful.
      Ask FixBot
    4. Epson Stylus Photo 820 Buttons Replacement: step 4, image 1 of 2 Epson Stylus Photo 820 Buttons Replacement: step 4, image 2 of 2
      • Insert the pointed end of a spudger into the hole on the bottom right corner of the printer and pry out the tab.
      Ask FixBot
    5. Epson Stylus Photo 820 Buttons Replacement: step 5, image 1 of 3 Epson Stylus Photo 820 Buttons Replacement: step 5, image 2 of 3 Epson Stylus Photo 820 Buttons Replacement: step 5, image 3 of 3
      • The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
      • The release points for the tabs are located in holes on the depressed area of the base (darker piece).
      • Use the pointed end of a spudger to pry out the tab.
      • Use one of the plastic tools to keep the tab pried out. Once it releases, push in towards the printer (viewing from the side) and pull up on the case.
      Ask FixBot
    6. Epson Stylus Photo 820 Buttons Replacement: step 6, image 1 of 1
      • All of the tabs have now been released.
      • When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
      • Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
      Ask FixBot
    7. Epson Stylus Photo 820 Buttons Replacement: step 7, image 1 of 2 Epson Stylus Photo 820 Buttons Replacement: step 7, image 2 of 2
      • Pull the cover up and off.
      Ask FixBot
    1. Epson Stylus Photo 820 Buttons Replacement, Buttons: step 8, image 1 of 2 Epson Stylus Photo 820 Buttons Replacement, Buttons: step 8, image 2 of 2
      • Locate the buttons.
      • Push the tabs in and pull up on the whole button piece to remove it.
      • Slide the replacement button piece into place until it clicks.
      Ask FixBot
Brandon Ivy
28 Reputation
1 Guide authored
Cal Poly, Team 20-68, Walters Spring 2011 Member of Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 38
All Time: 1,595
