Headlight Bulb Replacement
  1. Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Headlight Bulb Replacement: step 2, image 1 of 2 Headlight Bulb Replacement: step 2, image 2 of 2
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Headlight Bulb Replacement: step 3, image 1 of 3 Headlight Bulb Replacement: step 3, image 2 of 3 Headlight Bulb Replacement: step 3, image 3 of 3
    • Lift up and remove the metal wire cage holding the bulb in place.
  4. Headlight Bulb Replacement: step 4, image 1 of 1
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
To replace the bulb, follow the steps in reverse order.
Tim Asp
40,526 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 71
All Time: 3,809
