Haute42 S13 Button and Switch Replacement
  1. Haute42 S13 Button and Switch Replacement, Button Switch: step 1, image 1 of 1
    • Unplug the controller from any device it is connected to and make sure it is powered off.
  2. Haute42 S13 Button and Switch Replacement: step 2, image 1 of 3 Haute42 S13 Button and Switch Replacement: step 2, image 2 of 3 Haute42 S13 Button and Switch Replacement: step 2, image 3 of 3
    • Use a keycap puller to remove the keycap from its socket.
    • Avoid using excessive force to prevent damaging the device.
  3. Haute42 S13 Button and Switch Replacement: step 3, image 1 of 3 Haute42 S13 Button and Switch Replacement: step 3, image 2 of 3 Haute42 S13 Button and Switch Replacement: step 3, image 3 of 3
    • Use the keycap/switch puller to remove the switch from its socket.
    • Be careful not to damage the controller while removing the switch.
  4. Haute42 S13 Button and Switch Replacement: step 4, image 1 of 2 Haute42 S13 Button and Switch Replacement: step 4, image 2 of 2
    • Align the pins of the new switch with the holes in the socket and replace the switch.
    • You will feel the pins slide into place.
    • Do not press the switch in until you know you have aligned it correctly, doing so may damage the pins on the switch.
  5. Haute42 S13 Button and Switch Replacement: step 5, image 1 of 1
    • Use your finger to push the switch into place.
    • You should hear a click when it connects.
    • Try moving it to make sure it is firmly in place. It should not move at all when attached to the controller.
  6. Haute42 S13 Button and Switch Replacement: step 6, image 1 of 3 Haute42 S13 Button and Switch Replacement: step 6, image 2 of 3 Haute42 S13 Button and Switch Replacement: step 6, image 3 of 3
    • Align the cross on the keycap and the cross on the switch and gently press the keycap onto the switch.
    • Avoid applying excessive pressure to prevent damaging the new switch.
  7. Haute42 S13 Button and Switch Replacement: step 7, image 1 of 1
    • Take a look at the OLED input display on the controller while pressing it to check if the button is fully functional.
    • On the screen, the button should highlight itself and the input history should be displayed at the bottom. If it all works, congratulations! You have successfully replaced this button.
Finish Line
2 other people completed this guide.
Owen Santin
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 125
All Time: 963
