Domestic waterworks water bladder replacement
  1. Domestic waterworks water bladder replacement, Preliminary work: step 1, image 1 of 3 Domestic waterworks water bladder replacement, Preliminary work: step 1, image 2 of 3 Domestic waterworks water bladder replacement, Preliminary work: step 1, image 3 of 3
    • Domestic waterworks make off, then close the shut-off valve from the water inlet. Then Depressurize the waterworks by the water from a tap.
  2. Domestic waterworks water bladder replacement, Open the boiler: step 2, image 1 of 3 Domestic waterworks water bladder replacement, Open the boiler: step 2, image 2 of 3 Domestic waterworks water bladder replacement, Open the boiler: step 2, image 3 of 3
    • Loosen the screws with a 13 mm ring spanner, caution it runs out the water. Best to make a bucket to catch the water including. Then remove the cover. You can see the old bag. This can now be removed. The water bag is very dirty, therefore it is recommended to dress gloves
  3. Domestic waterworks water bladder replacement, Swap water bubble: step 3, image 1 of 3 Domestic waterworks water bladder replacement, Swap water bubble: step 3, image 2 of 3 Domestic waterworks water bladder replacement, Swap water bubble: step 3, image 3 of 3
    • Remove the water bag. Now is still the remaining water from the leaky water bag in the boiler. With a hose through the rest of the water suction vacuum.
  4. Domestic waterworks water bladder replacement, Clean the boiler: step 4, image 1 of 2 Domestic waterworks water bladder replacement, Clean the boiler: step 4, image 2 of 2
    • The boiler then clean with old rags, since this has quite a rust deposits.
  5. Domestic waterworks water bladder replacement, Insert new water bubble: step 5, image 1 of 3 Domestic waterworks water bladder replacement, Insert new water bubble: step 5, image 2 of 3 Domestic waterworks water bladder replacement, Insert new water bubble: step 5, image 3 of 3
    • Install the new water bag and then screw the lid. The screws should be not to tight. Please make sure that the water bag is properly seated. Usually this is more curved on a page, this page comes down.
  6. Domestic waterworks water bladder replacement, connection work: step 6, image 1 of 2 Domestic waterworks water bladder replacement, connection work: step 6, image 2 of 2
    • With a compressor or even foot pump produce about 1.5 bar pressure in the boiler. There should be no water in it. Then re-open the supply and take the House water system in operation. Possible must be drawn on a $!^&* to fill the pump a little water.
The water system should work now correctly.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Wolfgang
677 Reputation
3 Guides authored
3 Comments
Ich habe noch eine Frage.
Ist das Wasser in der Blase oder im Kessel ? Und wo ist der Druck 1,5 Bar ?
e.stolz48 - Reply
Das Wasser ist natürlich in der Blase, Der Druck von 1,5 bar ist im Kessel , Den muss man mit einem Kompressor einstellen, jedoch darf zu diesem Zeitpunkt kein Wasser in der Blase sein. Also kurz nach dem Einbau. Wenn dann die Blase gefüllt wird und das Wasserwerk angeht wird ja der Druck in der Blase gemessen. Wenn jetzt kein Vordruck im Kessel da wäre würde das Hauswasserwerk ziemlich schnell ausschalten.
Wolfgang - Reply
Hallo zusammen, ich habe bei einem Güde Inox 100/24 genau nach deinen Angaben gearbeitet. Leider wird der Deckel vorne nicht mehr dicht und es tritt Wasser aus.
hast du einen Tip warum?
marc_wiesner@gmx.de - Reply
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 128
All Time: 7,247
