Hasbro Bop-It Micro Series Back Case Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Hasbro Bop-It Micro Series Back Case Replacement, Back Case: step 1, image 1 of 1
      • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
      Ask FixBot
    2. Hasbro Bop-It Micro Series Back Case Replacement: step 2, image 1 of 1
      • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
      • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
      Ask FixBot
    3. Hasbro Bop-It Micro Series Back Case Replacement: step 3, image 1 of 1
      • Carefully separate the two sections, leaving them connected by the wires.
      Ask FixBot
Finish Line
James Schnabel
169 Reputation
2 Guides authored
IUPUI, Team 3-1, Harley Fall 2016 Member of IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 171
