Introduction
If the buttons on your device aren't working, it may be time to replace your control board. Follow this guide to do so.
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
4 other people completed this guide.
9 Comments
Where to get control board onyx 2.
My on/off button keeps blinking…..would somebody please email me cause I am a techno nitwit……..i’m gonna bring this piece of non chargeable crap outside and go Italian on it with the 12 gauge! SERENITY NOW!
Sincerely,
email ; jorcal3318@aol.com
power button continually blinks. Won’t turn on, can’t pair, no other action can be taken, just the blinking power button. what’s the solution? Please share….
Speaker plays for split second then fades away like wtf
Speaker comes on loud then Fades away like the volume is stuck on low
My volume button is not working,cant raise the volume on my speaker. And the volume is turned all the way down! Please help
Hi I have a problem with my control board
The volume will auto smaller and smaller until it's mute
Any idea to fix it or buy a replacement part?
And I want to buy replacement battery ,any stock available?
My email
My Bluetooth connection button is not working
Where can I find a new front panel for my speaker
consomme69 - Reply
If I take this off can I put it back on
Burger King - Reply
