Introduction
If you have looked at the troubleshooting page and identified that your issues with your Onyx Studio 2 are indeed due to the circuit board being bad, this guide will walk you through how to replace it.
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
Bisa di kirim
Bisa pesan 1
I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
11 other people completed this guide.
5 Comments
Where do I get another one
Where we buy the board?
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
Where can I Buy a new hk onix studio Main board?
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Where can I find a new front panel for my speaker
consomme69 - Reply
If I take this off can I put it back on
Burger King - Reply
