Up to 20% off select tools
Apple Time Capsule Model A1254 Hard Drive Replacement
Views: 26K
View statistics:
Past 24 Hours:
12
Past 7 Days:
63
Past 30 Days:
235
All Time:
25,852
Comments: 35
24 comments on steps, 11 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The hard drive is critical to the life of the device. The hard drive is a key piece of the time capsule, so awareness and moving slow through the steps is beneficial to ensuring no problems when the repair is made. This guide is do-able by anyone, but will not consume much time. If the user wants to add more storage then a replacement of the hard drive is a popular choice.
    1. Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: step 1, image 1 of 3 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: step 1, image 2 of 3 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: step 1, image 3 of 3
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      Ask FixBot
    2. Apple Time Capsule Model A1254 Hard Drive Replacement: step 2, image 1 of 2 Apple Time Capsule Model A1254 Hard Drive Replacement: step 2, image 2 of 2
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      Ask FixBot
    3. Apple Time Capsule Model A1254 Hard Drive Replacement: step 3, image 1 of 2 Apple Time Capsule Model A1254 Hard Drive Replacement: step 3, image 2 of 2
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      Ask FixBot
    1. Apple Time Capsule Model A1254 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
      • Peel off the adhesive backed foam from the top of the drive.
      • Lift the drive straight up and out of the device.
      Ask FixBot
    2. Apple Time Capsule Model A1254 Hard Drive Replacement: step 5, image 1 of 3 Apple Time Capsule Model A1254 Hard Drive Replacement: step 5, image 2 of 3 Apple Time Capsule Model A1254 Hard Drive Replacement: step 5, image 3 of 3
      • Remove the SATA connector and power connector from the end of the hard drive by simply pulling the cables straight away from the connection points.
      Ask FixBot
36 other people completed this guide.
Author
with
Patrick Butler
1,187 Reputation
2 Guides authored
Cal Poly, Team 4-2, Livingston Fall 2016 Member of Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Members
60 Guides authored
11 Guide Comments
What’s the max hard drive a Time Machine can take?
ice2257 - Reply Share
This answer: What's the biggest HDD that will fit on my Time Capsule? suggests that you can use pretty much any available drive. If it could take a 4TB in 2014 (one of the answers), I don’t think there would be any limit practically speaking.
odaiwai - Reply Share
Great guide. One note. My unit was quite old and the rubber mat was brittle. Even with a heat gun and spudger I still tore it in several places. This might be avoided by heating up a cloth in a microwave first and applying it to the rubber before beginning to pull it off. Just a thought.
wfstapleton - Reply Share
I’m not seeing a guide for the Apple Time Capsule 2TB MC344LLA / A1355 so I’ll have to see which one is closer to my model when it arrives,
But in the meantime has anyone been able to upgrade the hard drive past 2TB without any issues?
Is a Firmware update needed to do so?
David Bell - Reply Share
I installed a 3 TB about 7 years ago in mine. i’m here now because I can’t get it to power on.
Nubs34 - Reply Share
Past 24 Hours: 12
Past 7 Days: 63
Past 30 Days: 235
All Time: 25,852
