In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Insert with hammer the fork as much as you can back into the handle.
Drill both the handle and the fork with a small drill bit. Here diameter 3mm.
Insert a pin throught both parts. Normally, the pin should hold inside by friction.
I advice to drill close to the ring holding the wooden handle in one part. It is advisable because the pin will have tendency to split the handle appart, therefore the presence of the ring is vital.
The hand fork is stronger than before.
