Hamilton Beach Power Cord Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
102
All Time:
2,198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
This page will guide you through the replacement of the power cord on your Hamilton Beach Classic Stand Mixer 64650. This guide is helpful if you are experiencing any problems with turning on the mixer. If your device will not turn on despite all efforts, this is probably the best guide for you to follow!
Tools
    1. Hamilton Beach  Power Cord Replacement, Motor: step 1, image 1 of 3 Hamilton Beach  Power Cord Replacement, Motor: step 1, image 2 of 3 Hamilton Beach  Power Cord Replacement, Motor: step 1, image 3 of 3
      • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
      Ask FixBot
    2. Hamilton Beach  Power Cord Replacement: step 2, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 2, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 2, image 3 of 3
      • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
      Ask FixBot
    3. Hamilton Beach  Power Cord Replacement: step 3, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 3, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 3, image 3 of 3
      • Carefully pull the motor block out of the case.
      • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
      • Handle the wires with care to ensure you do not break any of them.
      Ask FixBot
    4. Hamilton Beach  Power Cord Replacement: step 4, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 4, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 4, image 3 of 3
      • Desolder the six wires connected to the motor using this guide.
      • Make sure to note colors when you disconnect them and remember where to reconnect them later.
      Ask FixBot
    5. Hamilton Beach  Power Cord Replacement: step 5, image 1 of 2 Hamilton Beach  Power Cord Replacement: step 5, image 2 of 2
      • Once disconnected, the motor will slide out easily.
      Ask FixBot
    1. Hamilton Beach  Power Cord Replacement, Speed Level: step 6, image 1 of 3 Hamilton Beach  Power Cord Replacement, Speed Level: step 6, image 2 of 3 Hamilton Beach  Power Cord Replacement, Speed Level: step 6, image 3 of 3
      • Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
      Ask FixBot
    2. Hamilton Beach  Power Cord Replacement: step 7, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 7, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
      Ask FixBot
    3. Hamilton Beach  Power Cord Replacement: step 8, image 1 of 2 Hamilton Beach  Power Cord Replacement: step 8, image 2 of 2
      • Remove the handle's cap carefully.
      • Watch out for the quick burst button, it likes to run away.
      Ask FixBot
    4. Hamilton Beach  Power Cord Replacement: step 9, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 9, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 9, image 3 of 3
      • Slide the speed switch forward and lift upward off of the handle.
      Ask FixBot
    5. Hamilton Beach  Power Cord Replacement: step 10, image 1 of 2 Hamilton Beach  Power Cord Replacement: step 10, image 2 of 2
      • Remove speed level from the inside of the case by applying light pressure toward you.
      • Do not pull on the wires to remove the speed level.
      Ask FixBot
    6. Hamilton Beach  Power Cord Replacement: step 11, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 11, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 11, image 3 of 3
      • Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
      • Replace the speed level assembly.
      Ask FixBot
    1. Hamilton Beach  Power Cord Replacement, Power Cord: step 12, image 1 of 3 Hamilton Beach  Power Cord Replacement, Power Cord: step 12, image 2 of 3 Hamilton Beach  Power Cord Replacement, Power Cord: step 12, image 3 of 3
      • Liftback end of the handle up from motor casing.
      • Pull back to detach fully from the stainless steel.
      Ask FixBot
    2. Hamilton Beach  Power Cord Replacement: step 13, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 13, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 13, image 3 of 3
      • Remove the three 7.8 mm Philips #2 screws holding the power cord in place.
      Ask FixBot
    3. Hamilton Beach  Power Cord Replacement: step 14, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 14, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 14, image 3 of 3
      • Cut zip tie holding the power cable together using handheld wire cutters.
      Ask FixBot
    4. Hamilton Beach  Power Cord Replacement: step 15, image 1 of 3 Hamilton Beach  Power Cord Replacement: step 15, image 2 of 3 Hamilton Beach  Power Cord Replacement: step 15, image 3 of 3
      • Untie the black lead's knot.
      • Cut both wires with handheld wire cutters.
      • Follow this guide to solder new power cord wires in.
      Ask FixBot
Gwen Davis
519 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 102
All Time: 2,198
