Up to 20% off select tools
Halogen Headlight Bulbs Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
150
All Time:
183
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Did you know that halogen headlights deteriorate and grow dimmer over time? In fact, on older cars halogen headlamps can lose up to 80% of their brightness due to the bulb alone. Combine that with foggy headlight lenses and it can become really dangerous. Fear not because good bulbs are available online for less than $20 a pair. And 3M makes an excellent headlight lens restoration kit that's pretty awesome for 2 lights at about $15.
How to proceed if your headlights are looking janky:
  1. Look at your owners' guide, online, or AI to confirm that your car or truck has halogen headlights. Make a note of what type is used on the low beam headlights on your car. Many US cars use H11 bulbs.
# Pop the hood on your car and turn on your headlights. Switch the bright lights on and off to figure out which lamps are high beams and which are low beams. This problem would apply to the low beams. Shut off the headlights and locate the plug on the back of the bulb remove the lamp and plug to inspect that the plug is in good shape. Your tube will have videos on how to do that on your car.
  1. Order 2 of the correct bulbs for your car. Install them when they arrive.
  2. If your headlight lens is foggy, I have used this 3M product to make them like new except for a few of those inside cracks you may see. I think that's called "craizing" but the headlights look great using a simple hand drill and a little patience. This kit is enough to restore two headlights. 3M Headlight Restorer for 2 Headlights
Randy Tolleson
473 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 150
All Time: 183
