Hafury Umax Disassembly
Video Guide
This guide was transcribed from a YouTube video.
      • Power off the Hafury Umax and unplug the charging cable before you begin.
      • Work on a clean, dry, static-safe surface with good lighting.
      • Use metal tools only on screws, and keep them away from the battery and exposed contacts.
      • Stop if the battery is swollen, hot, leaking, or smells unusual.
      Ask FixBot
      • Place the phone on the work surface with the visible screw heads facing up.
      • This basic disassembly is useful when a broken charging connector requires internal access.
      • Take a clear photo of the screw locations before removal if you want a reference for later repair work.
      Ask FixBot
      • Use a precision screwdriver to remove the visible screws from the exposed phone frame.
      • Keep the screwdriver straight and press down firmly enough to avoid stripping the screw heads.
      • Remove every visible screw before lifting, separating, or prying any internal parts.
      • Group the screws by location so they don't get mixed up during any separate repair or reassembly work.
      Ask FixBot
      • Check that no visible screws remain in the area you plan to access.
      • Do not force the frame, board, or connector area if it resists after the screws are removed.
      • Stop here if you only need the basic disassembly covered by this guide.
      • Power connector repair requires a separate component-level procedure.
      Ask FixBot
The Hafury Umax is ready for a component-specific repair guide. Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Mr. Camarium
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 55
All Time: 142
