Shop the Holiday Gift Guide
MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement
Views: 66K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
140
All Time:
66,216
Comments: 30
27 comments on steps, 3 guide comments.
Go to guide comments
Completed: 56
56 people have marked this guide "completed." Will you be next?
Favorites: 31
31 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace the subwoofer & right speaker in your MacBook Pro 13" Unibody Mid 2010.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Remove the lower case screws: step 1, image 1 of 1
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Lift the lower case away: step 2, image 1 of 1
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Battery: step 3, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Optical Drive: step 4, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
      • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 5, image 1 of 1
      • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
      • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
      • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
      Ask FixBot
    3. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
      Ask FixBot
    4. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 7, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
      Ask FixBot
    5. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 8, image 1 of 1
      • Remove the following screws securing the subwoofer to the upper case:
      • One 3.8 mm Phillips screw
      • One 5 mm Phillips screw
      Ask FixBot
    6. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 9, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 9, image 2 of 2
      • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
      • Lift the subwoofer off the optical drive, and set it above the computer.
      Ask FixBot
    7. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 10, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 10, image 2 of 2
      • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
      • The leftmost screw may remain captive in the camera cable.
      • Lift the camera cable bracket out of the upper case.
      Ask FixBot
    8. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 11, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 11, image 2 of 2
      • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
      • Lift the optical drive from its right edge and pull it out of the computer.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: step 12, image 1 of 1
      • Peel back the small piece of black tape covering the right speaker cable.
      • Be careful, as the power button ribbon cable is directly under this piece of tape.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 13, image 1 of 1
      • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
      Ask FixBot
    3. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 14, image 1 of 1
      • Lift the subwoofer and right speaker assembly out of the upper case.
      Ask FixBot
56 other people completed this guide.
Author
with
Walter Galan
711,864 Reputation
1,203 Guides authored
3 Guide Comments
Oh yeaAAHHH! Right speaker & subwoofer fixed. Thank you!
eepmon - Reply Share
The replacement subwoofer connector (step 4, which disconnection is required, not optional)was just a bit shorter, and just barely fit, so it was ‘iffy’ whether I’d get it to stay, but it did. Yea! No more sound distortion!!! Such an easy thing to fix!
wyrra - Reply Share
Hello, I've just brought a MacBook Pro 8,1 to life with an SSD. It works great but unfortunately no sound. There is no output listed in sound window. I tried cmd+opt+P+R without success. Would replacing the speaker assembly solve the problem or is this a hardware problem? Thanx
PS- I also restarted cord...something in processes that didn't work either.
edwood - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 140
All Time: 66,216
