Shop the Holiday Gift Guide
HTC Vive Facerest Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
5
All Time:
81
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 4 minutes
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
The HTC Vive's facerest may need replacement when it feels uncomfortable against your face or gets dirty. This guide will show you how to replace the Vive's facerest.
Parts
Tools
    1. HTC Vive Facerest Replacement, Straps and Cables: step 1, image 1 of 3 HTC Vive Facerest Replacement, Straps and Cables: step 1, image 2 of 3 HTC Vive Facerest Replacement, Straps and Cables: step 1, image 3 of 3
      • Slide the HTC panel covering the cables forward, away from the Vive.
      • Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
      Ask FixBot
    2. HTC Vive Facerest Replacement: step 2, image 1 of 1
      • Undo the hook and loop tape on the straps.
      • Slide the ends of the straps through the hinge loops.
      Ask FixBot
    1. HTC Vive Facerest Replacement, Facerest: step 3, image 1 of 1
      • Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
      Ask FixBot
    2. HTC Vive Facerest Replacement: step 4, image 1 of 2 HTC Vive Facerest Replacement: step 4, image 2 of 2
      • Use a T6 Torx Screwdriver to remove either of the two 12mm hinge screws holding the two hinges in place.
      • Allow the hinge to fall away once the screw is removed.
      • Repeat for the opposite side.
      Ask FixBot
    3. HTC Vive Facerest Replacement: step 5, image 1 of 3 HTC Vive Facerest Replacement: step 5, image 2 of 3 HTC Vive Facerest Replacement: step 5, image 3 of 3
      • Slide the plastic facerest away from the device.
      Ask FixBot
Author
with
Caleb Watts
2,439 Reputation
11 Guides authored
Cal Poly, Team S18-G1, Forte Fall 2017 Member of Cal Poly, Team S18-G1, Forte Fall 2017
CPSU-FORTE-F17S18G1
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 81
