HTC Vive Controller Battery Replacement
  1. HTC Vive Controller Battery Replacement, Saucer Panels: step 1, image 1 of 3 HTC Vive Controller Battery Replacement, Saucer Panels: step 1, image 2 of 3 HTC Vive Controller Battery Replacement, Saucer Panels: step 1, image 3 of 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Ask FixBot
  2. HTC Vive Controller Battery Replacement: step 2, image 1 of 2 HTC Vive Controller Battery Replacement: step 2, image 2 of 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    Ask FixBot
  3. HTC Vive Controller Battery Replacement: step 3, image 1 of 2 HTC Vive Controller Battery Replacement: step 3, image 2 of 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    Ask FixBot
  4. HTC Vive Controller Battery Replacement: step 4, image 1 of 3 HTC Vive Controller Battery Replacement: step 4, image 2 of 3 HTC Vive Controller Battery Replacement: step 4, image 3 of 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    Ask FixBot
  5. HTC Vive Controller Battery Replacement, Front Panel: step 5, image 1 of 2 HTC Vive Controller Battery Replacement, Front Panel: step 5, image 2 of 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    Ask FixBot
  6. HTC Vive Controller Battery Replacement: step 6, image 1 of 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Ask FixBot
  7. HTC Vive Controller Battery Replacement: step 7, image 1 of 2 HTC Vive Controller Battery Replacement: step 7, image 2 of 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    Ask FixBot
  8. HTC Vive Controller Battery Replacement: step 8, image 1 of 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    Ask FixBot
  9. HTC Vive Controller Battery Replacement: step 9, image 1 of 2 HTC Vive Controller Battery Replacement: step 9, image 2 of 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    Ask FixBot
  10. HTC Vive Controller Battery Replacement: step 10, image 1 of 3 HTC Vive Controller Battery Replacement: step 10, image 2 of 3 HTC Vive Controller Battery Replacement: step 10, image 3 of 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    Ask FixBot
  11. HTC Vive Controller Battery Replacement, Battery: step 11, image 1 of 2 HTC Vive Controller Battery Replacement, Battery: step 11, image 2 of 2
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
    Ask FixBot
  12. HTC Vive Controller Battery Replacement: step 12, image 1 of 1
    • Remove the silver plate by pinching it with two fingers and lifting up.
    Ask FixBot
  13. HTC Vive Controller Battery Replacement: step 13, image 1 of 1
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
    Ask FixBot
  14. HTC Vive Controller Battery Replacement: step 14, image 1 of 2 HTC Vive Controller Battery Replacement: step 14, image 2 of 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    Ask FixBot
  15. HTC Vive Controller Battery Replacement: step 15, image 1 of 2 HTC Vive Controller Battery Replacement: step 15, image 2 of 2
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    Ask FixBot
  16. HTC Vive Controller Battery Replacement: step 16, image 1 of 3 HTC Vive Controller Battery Replacement: step 16, image 2 of 3 HTC Vive Controller Battery Replacement: step 16, image 3 of 3
    • Lift the battery frame to remove the battery from the Vive controller
    Ask FixBot
34 other people completed this guide.
Ryan Grewohl
893 Reputation
3 Guides authored
Cal Poly, Team S15-G5, Livingston Fall 2017 Member of Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Members
51 Guides authored
14 Guide Comments
well if theres no parts…then theres no point…
altimmons - Reply Share
So, where do I get a replacement battery from? Does anyone know the part number?
scotty - Reply Share
This helped me ALOT. i had a controller stop charging or powering on. Decided to use this guide to pull just pull power and re seed the connection for the battery. The Battery connection IS NOT CLIPPED IN. TAPE holds down the connection to the terminals. So it can easy come loose over jolts and shocks or normal use
Mike Moutrie - Reply Share
battery is 3.85vdc 960ma
HTC model boplh100
3.69Whr
Part number 35H00244-00M
guido - Reply Share
With all the comments and steps, I easily took apart and rebuilt my controller. Thank you!!
Also, I used this cheap repair kit they sell at walmart if you dont have the tools and don't want to order them online.
https://www.walmart.com/ip/Hyper-Tough-T...
A K - Reply Share
Past 24 Hours: 10
Past 7 Days: 73
Past 30 Days: 274
All Time: 49,211
